Premium members don't see ads. Click here to upgrade.
0° camber on front and back. -1° on front?
Don mercier
Cochrane ont
Senton
Ok ive set my camber too 0° on the back, -1° on the front on my senton. Been playing with this for days. My front toe in at - 2°.
The rear is fixed to about 4°. Its brand new and will not drive straight no matter what i do. Its a sentin 3s blx brushless, any suggestions? If i go slow it will drive fairly straight but once i give it a bit of speed it wanders, all the bearing are free
crimsonfancy
A guy that doesn't know when to give up.
South Louisiana
BigRock 4x4, Kraton 6s, Notorious, Talion, Typhon 6s
Is it because the steering is sensitive? My BRCC was very sensitive but seems to be easier to drive now that I have the bigger tires and 6mm extensions installed.
Don mercier
Cochrane ont
Senton
When i first got it i couldnt keep it straight, lost controle and hit something full speed, fixed it and been playing with camber and managed to get it to drive much better, the steering rack has alot of play, ive also shimed the bearings were really sloppy. Getting there, if i give it more toe in with it be less touchy?
Notorious J
🦖🏀#1!
The Six baby! We The North! Raptors NBA champs!
Notorious, Outcast 6s
Steering trim? Try turning the knob in tiny increments while stopped. Going perfectly straight is never easy. One tire could be spinning slightly faster too, which could be caused by a ton of different things. Try the trim and see if you can't find a decent mid point.
bicketybam
BickeringBam - YouTube Mega Star!
ArrmaForum Fan
New Milford, CT
BigRock 4x4, Granite, Notorious, Talion
HR Steering bellcrank and aluminum pivot balls will do wonders.
