- Location
- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
This is not gonna be the typical build,cause the cars already built....really just wanna share on how an what I've done to build this car....so I'm gonna be jumping around on the phases of the build.hell,I'm might just disassemble it an rebuild it...I'll order bearing kit an do it in a few days when they arrive..this is basically my mini-typhon that I will be installing a deltaplastiks speedrun body on...this is the 3rd mini I've built...EXTREMELY LIGHT,VERY FAST.no need for anymore than 4s with these cars.these mini cars are the MOST extreme cars I've ever done.i totaled out the first 2 minis within a month of building them.lost control of 1 at 116mph an crashed it into the back of @real_name_hidden personal car...mini exploded.today I got body so here's where sits today...
Swb granite chassis
Vendetta suspension an towers
Mmx8s an tp4030-4400kv
Mod1 spool
So when my beating kit arrives I'll tear car down an rebuild an go into detail on every part used on car....I've run 98mph on 3s with typhon body with car......motor is good for 4s...should be very impressive with this body on 4s.....size comparison next to 1/8 typhon 6s
I've do have some custom work to figure out on this car.......I'm going to figure out how to mount 1/10 bsr foam dirt oval tires on car...I think I have it figured out ,just waiting on a few parts .hub clearance will be the issue..these tires are much smaller an lighter than the grps currently on car..68mm bsr compared to 98mm grp......I've got lots of room for gearing up so tire size isn't a concern
Swb granite chassis
Mod1 spool
