- Felony
- Fireteam
- Infraction
- Limitless
- Kraton 8S
- Kraton EXB
- Kraton 4s
- Mojave EXB
- Notorious
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 3s
- Typhon 6s
- Typhon TLR
- Thread starter
- #21
Thanks man I'm definitely going to consider that. Going to be an adventure trying to build a traxxas from the chassis up!Foams will chunk in the first 5 mins as a parking lot basher.
Id probably go with a 4tec 2.0 and just swap that motor in with a MMX6s esc. Everything should fit.
This was a 4tec 2.0 with a tp 4050 and mmx8s.
I cut the sides of the chassis and then put a piece of carbon over the top of the plastic chassis so that I could put the 2s packs on each side.
The saga chassis will make it waaaay easier to run mod 1 gears and fit everything you want in there.
