What parts would do I need to make this 1/5 kraton go 80mph?? Asking for a friend
The wheelies come from the large and heavy tires as much as it does traction. You can greatly reduce this effect going to smaller and lighter tires.So I just picked up a kraton exb 8s to compliment my exb outcast 8s specifically thinking to set it up as a high speed cruise missile for bigger terrain driving. My 1/5 outcast exb with a HW max5 1100 kv combo is fast, very comparable to the 6s nor=torious. Though I haven’t actually put a gps on it, I think it probably does about 55 - 60 max off-road, assuming flat open fairly short cut grass and a good wide open space to gently get it to speed… though just speculation of coarse.
‘the biggest issue with getting these rigs, 8th or 5th scale to max speed isn’t power or motor size, it’s keeping the front wheels down. We can put so much power in these that with bigger high traction tires off road most set ups top speed limit comes well before you run out of power.
I was just looking at he copperhead 2s on the exb 8s kraton tonight and was surprised how big the tires where compared to the outcast version. I am not sure the kraton exb will go much faster with those huge tires before lifting the front, there almost 5’ wide! I may try the outcast tired or some belted mashers If the kraton lifts too easy with the copperheads.
‘I am going to run the xlx2 and 1100 kv combo in the kraton, probably enough power to reach close to 80 even off-road if geared right, but keeping Ion 4 wheels is the hard part!
