Even more confused !! Lol
So the Kraton drives like a buggy ?
Not sure what you mean le3phturn?
I do like the looks of the 8s outcast !!!
But I like the 8s Kraton as well
As far as the 60mph jumps
Uhm….. yeah
We have a creek that runs thru the farm it’s anywhere from 20 to 30 feet from bank to bank and I can promise if which either 1/5 scale exb I end up with , I will be “sending it “ over said crick!!!! Most likely as fast as I can
The Typhon will jump it but it doesn’t like the hayfield grass sometimes and loses speed and basic control!!!
Dang it
Priorities!!!!!!
The Kraton is sort of a hybrid between a Truggy and a monster truck/stunt truck. One end of that spectrum is the Typhon - low, fast, handles amazing, and stable. Not a wheelie or backflip machine. The opposite end of that spectrum is the Outcast. Short wheelbase, much higher with much heavier wheels and tires and a short wheelbase. Much more ground clearance. Wheelies and standing backflips. If you can pull a back flip off a jump with the Kraton you can get a double with the Outcast. It is a true stunt truck and I love it. Wheelies for days, front flips, back flips, stoppies, all kinds of madness that the Kraton can't quite match. If you've had a Typhon and you get an Outcast you have both types of rig. If you can only choose one the Kraton can do everything fairly well, just not as well as either of those two.
If your top priority is flight, I think the Kraton will be the better choice purely because you can get it up to speed more easily without doing wheelies. If you are talking forward and backward flips in the air, you can rotate faster with the Outcast. If you want long distance and less sensitivity in the air, the Kraton may be the better choice.
