Can I please get some recommendations for a cooling on my 1/5th scale motor (2028)?
Have you used it and if so how does it work?Assuming 2028 is 56mm this mount and a 40mm fan. Or maybe two of each if they fit width wise...
https://www.ebay.com/itm/303935919756?hash=item46c3fe168c:g:7jsAAOSwB59gZPVS
https://www.ebay.com/itm/353317284977?hash=item524359ec71:g:RdEAAOSwQaBf1Y6a
Notthis one but the 40-42mm one works the same way. These big ones are kind of new as I just noticed them a few days ago and the 45-49mm ones as well. It holds up one side of the fan with those mounting holes. If you use the aluminum fan I linked to it will be strong enough for bashing. That big 2028 can may have enough room for two mounts and you could make a little bridge to fasten the fans to each other for a super rigid set up.Have you used it and if so how does it work?
