yea i already have xt90s on them setup for my kraton 6s and 7in drone , i bought a flier 400a 4-16s esc and went with a casstle 800kv 2028 sensored motor and savox sw0241mg for the servo. it just doesn't make sense to me to have the same power setup as my kraton 6s if im going bigger we need MORE POWER BABY! lol just makes it easy for me that everything i have takes 6s batteriesIf those are the beast/xclass packs with the AS150 connectors then you're pretty much good to go! If you have XT60s on them you definitely want to look into changing them over to XT90, IC5, QS8 or AS150 connectors before running them in 12s.
On the ESC, I agree with @Lovestricken, skip the ZTW and invest in a MTM if you're dead set on 12s.
On the other hand, you could just run a Max5/XLX2 on 6s... less power and speed but if you put in one pack at a time it will also weight less!
Unless you put a throttle limit on the 12s setup you'll just have way more power than you can reasonably use and end up putting a ton of wear on the drivetrain, which cost you in replaced gears/diffs/cvds.
I kinda feel ya on that. I am running a monster system on my kraton 6s.. hobbywing 5687 and a castle 2028 on my k8 exb. Same power rating just a longer can... but the castle does handle 10s which is probably the sweet spot for the k8.yea i already have xt90s on them setup for my kraton 6s and 7in drone , i bought a flier 400a 4-16s esc and went with a casstle 800kv 2028 sensored motor and savox sw0241mg for the servo i just doesn't make sense to me to have the same power setup as my kraton 6s if im going bigger we need MORE POWER BABY! lol just makes it easy for me that everything i have takes 6s batteries
I understand where you are going with it and if you plan to keep running xt90s then high voltage low amps is the way to go.yea i already have xt90s on them setup for my kraton 6s and 7in drone , i bought a flier 400a 4-16s esc and went with a casstle 800kv 2028 sensored motor and savox sw0241mg for the servo. it just doesn't make sense to me to have the same power setup as my kraton 6s if im going bigger we need MORE POWER BABY! lol just makes it easy for me that everything i have takes 6s batteries
Oh wow... those Flier ESCs look sketchy AF! Here's hoping they work better than they look!yea i already have xt90s on them setup for my kraton 6s and 7in drone , i bought a flier 400a 4-16s esc and went with a casstle 800kv 2028 sensored motor and savox sw0241mg for the servo. it just doesn't make sense to me to have the same power setup as my kraton 6s if im going bigger we need MORE POWER BABY! lol just makes it easy for me that everything i have takes 6s batteries
Based on what I have seen they handle low KV motors ok and some general use. (not good for speed runs)Oh wow... those Flier ESCs look sketchy AF! Here's hoping they work better than they look!
For 12s mgm esc and motor. There is ztw but they catch fire often on 12s. 12s is going to be overkill. 10s is more usable power. Every video I have seen on 12s they can't even keep it in a straight line or even keep tires on it.
No I wouldn't ever own a hobbystar. Yes I have the exb version the day it released. I have the castle 2028.
Like i stated in my comment. From videos I have seen. On 12s tires rip apart. Granted that's on the standard copperheads and not the big blocks. Plus it just wants to pull the front end. I didn't say it wasn't doable or suggested. Just that 10s would be a much more usable power range. I seen them on 16s ... being they already have drive axle issues breaking. Imo 10s would be better suited for the avg person looking to have more kick. People like you are the rare that want to time travel lol. Glad it works good for you. As far as the ztw. Lots of them go poof on YouTube in many different vehicles.
Yup my post
Wasn't giving a review. Was asking for reviews but you already knew that.
Btw here is the imaginary unicorn I don't own
Not sure what I did to anger you so greatly but sorry you are having such a hard time getting myself out of your head.
Just tossing out an idea, couldn’t you run an XLX2/2028-1100kv setup and run parallel 6S packs?
