SrC
RC is a lifestyle choice
Hospitality Award
- Location
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
Many AF members requested that Arrma make a 1/5 Typhon for 2021.
I would also like that and this inspired me to Build a 1/6 version of that from my parts bin.
I went through my bins and came up with these parts and assembled one easy enough
My parts:
- Mojave parts; Extra long wheelbase chassis, front shock tower, FR braces and T2T brace (CF sleeved)
- Kraton F/C/R diffs (60kF-500kC-30kR)
- Kraton V3 Rear tower
- 4 Kraton shocks (1.2mm pistons F/R; 1k CST)
-Stock BXL185 ESC/2050Kv
-DS3235sg Servo.
- Mojave ST mount
-6S Kraton Wing ( ordered a1/5 OC wing to try)
_Power Hobby 35mm ESC Fan
-30mm Turbo alloy motor fan/Exotek fan mount, 20mm HS and 20mm Fan mounted to the motor end plate.
-Kraton Front arms and all related axles, bones etc.
-RPM Rear arms and Rpm dirt guards
-M2C outdrive cups and input cups
-M2C hex adapters
-T-Bone racing F/R bumpers for the Mojave. ( just lying around new unused, didn't like them better than the stock Mojave bumpers on my Mojave RTR)
-1 Limitless Front body post at the front
- Notorious front body posts and mounts for the rear
-Mojave A and D blocks
-Kraton hubs F/R, PB's etc
-Mojave battery box and RX box
- 4 Samix SS double flanged balls ( for rear body mount spacing at the rear tower)
-Arrma adjustable wing mount low/high rise
-Mojave chassi side guards
- 4 BF LP tires/wheels and 4 DTX 1/8 Truggy X-Con pins (zero offset) to experiment with. I also have 4 Hoons Rear Fel. 53/107's on the way. White was all I could find. Wanted Silvers.
-Notorious Center cage
-Limitless stock painted body (trimmed at the rear) with a custom nose piece for the front ( made out of the rear scrap)
-Kraton ST top plate and bell crank with BB's.
Th chassis (with body) weighs in at 9 pounds without wheels and lipo. ( no upgrade alloys)
The Wheelbase is 16 3/4 inches long. Wheel Track is Stock Kraton width.
It is not finished and I may need to alter center diff gearing ( maybe a 46T spur) depending on the tires I end up with. I would expect 55mph as my target as it sits now.
Just need to drive it. Considering EXB arms F/R and stiffer Fr. springs I have sitting here.
Needs a shake down in the dirt after a few speed passes on pavement.
I will keep this Updated.
I have to thank a few members for pushing me post it here.
I am sure this has been done by someone else somewhere.
I've seen Off road Lims before.
But this is a Lim body fitted onto an Extra Long Wheelbase 1/6-1/7 chassis.
My parts:
-DS3235sg Servo.
- Mojave ST mount
-M2C hex adapters
