Stretch your Typhon and the limitless v2 spool will work
Stock Typhon v1 spool
^^^ +1
I said the same to myself. The V1 lim spool would simplify things perhaps. And should suffice.
Then you could use a stock center shaft setup for the respective chassis.
I must have missed that spool on there. My apologies.
Now that I think of it...with th3 34t cheaper spool I have now and the 25t and 29t pinions I have to mate with it... the 29t was making my esc cut out and the 25t wouldn't meet the spool with the stock motor mount unless I'm looking at it all wrong. The 29t pinion mated with the 34t spool was at the end of the travel for the stock mount, so the 25 tooth wouldn't mesh probably. As you said in an earlier post, the 27 is the sweet spot. I might have to grab that pinion tooth count.
I have an 8s Spektrum esc from my K8 sitting on my bench. I'm going to try that in it to see if I can get that 100mph as I think the 150amp rsc is cutting out. Trying not to buy another set of electronics.
