So I finally got a my car out and did a couple 90mph passes and noticed the front end was lifting a little, so I lowered the front and went up in the rear a little. Seemed better so I went for a faster pass and probably at 105 maybe she did a beautiful backflip haha. No worries just some scratches and rear axle popped out. Anyways went home and did some more tuning and basically put the front suspension all the way down and rear up quite a bit but the front is on the ground now and has basically no travel. Just wondering if I should just run it like that and let the foam peice grind down a little naturally, and also should I just remove the wing? You can tell on the body that the wing has too much downforce and just pushed the ass end all the way down. If anyone's got some suggestions before my next run, let me know because that was at under 75% throttle so she's gonna hit 120+. Also it's got the kraton 8s electronics in it so it's pretty heavy in the front which I thought would be enough.
