Notorious J
It's gonna break, so might as well send it!
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- On a midnight train to nowhere
- Gorgon
- Granite
- Notorious
- Typhon 6s
Discussed here once before without definitive answer. Can you run a 4092 1250kv motor w/ a 160A or larger esc on 6s? Will it be too underpowered in a Kraton or Notorious? If it can run, what pinion might be ideal for a basher? Will there be issues with cogging? Top speed is not the goal here, just a good handling basher/jumper/trickster. Esc contenders would be HW Max 6, Castle MM2 or similar. 8s is out of the question.
Reason behind this question is that I received the wrong motor. Was supposed to be 1650kv which was my ideal choice for said application. Ok team, let's here what direction you plan to head me in.
