17s would be better more tire options and a less stripped rimsI cant decide what size hexs to to run on a mega senton any suggestions thanks
You don't always gotta run bigger tires if you have 17mm hexs you can also find 2.8 tires in 17mm or even 1/8 buggy tires work good only 112mm diameter usuallyAre there drawbacks from running bigger tires, such as more wear on parts, motor, esc or throwing things out of alignment? e.g. the 12mm Proline SuperSwampers are the same approximate size as the stock tires. The 17mm version is almost 2" wider and taller.
Ha I have a mega, what wheel hexes should I use I want 12mm only because I run that on all my cars just like I run deans on all of them too. Thanks meeHave you considered the slop you will end up with, with the 17mm wheel adapters? It was too much for me...I went to 12mm
I have a mega and can you tell me what 12mm hex will fit it.?
