Deepdish32
- Kraton 8S
Hello everyone this is my first post, so please if there is anything I should correct just let me know. I would like to share and let everyone know that the kraton 8s platform is great, the drivetrain is strong, wheel base length and width is perfect to handle 50volt 12s systems. Yes the stock chassis has issues but there are aftermarket 6061 and 7075 alloy chassis and bracing available, not to mention Arrma just released the 1.5 version with better chassis bracing. With this current 12s Kraton build, I have worked closely with MGM compro and Castle Creations to have the first working 12s sensored Castle 2028 800kv system. The MGM X2pro 25063-3 esc I used is not cheap but comes with Data monitoring, a ton of customized settings, sensor capabilities, 4 vehicle profiles, and 5 year warranty. The Castle Creations 12s 2028 800kv sensored Ywind 4 pole motor won it for this build over the aggressive amp hungry TPPower 12s 5870 800kv sensorless Dwind 6pole motor. The TP motor was ruff the 6 pole magnetism resistance was harsh and the motor being sensorless it was like the power was just uncontrollable because esc doesn't know the motors position from a stop to a go. Rhe 12s to motor already killed 2 ZTW/HOBBYSTAR 12s esc's in a matter of seconds. It worked with the MGM but the 20 hp 15000 watt motor was just too much for a 30 pound car. I always liked the castle 2028 800kv sensorless motor with the ZTW/Hobbystar 12s esc in my x maxx but I wanted to try the new sensored version with the MGM esc. All I can is wow just wow Castle 2028 800kv sensored on 12s with the MGM is the perfect match just check out the footage in you tube links. I used OSE 8mm antispark connectors with two Powerhobby 6s 100c 8000 mah packs and they deliver supply power no problem and have long runtimes with this build, but mainly because of the efficient sensored esc motor combination . I added a x maxx heatsink for the castle 2028 motor with a 50×50×28 40CFM fan but with all the bashing in the videos the sensored 12s 2028 motor would not get hot at all with the powerful cooling fan off. The motor is quite, super smooth, and takes whatever power the MGM esc lets through its Transistor switches. I include a snapshot of the amp data from esc and amps reached as high as 800amps which is crazy. I used a mod 1.0 33t pinion and 47t stock spur in these videos and I cant believe how fast this kraton is with mild gearing. In one of the pictures I changed the spur to a Arrma infraction spur 39t but I have not ran that gear setup yet, I expect to gain atleast 10mph extra offroad. I am using a 30mm spaced unpolished motor mount from ebay. M2C racing polish 7075 chassis. My own custom built 6061 3/8×3/4"inch rectangle alloy for top brace. Proline badland bead lock wheels, I drilled out the bore with step bit to fit the kraton spindle. I am just happy with the outcome of this build and the fact that castle is releasing a sensored 12s esc soon is just great. I do believe 12s 800kv sensored setups will be the future for big scale R/C's. Please check out the footage, more videos and post to come. Please share your 12s, 10s or 8s kraton builds. If anyone has any suggestions please comment. Well thanks for letting me share this post.
