12s Rovan f5 Monsta!!
Looks like a beast. You have to give more details.
I could listen to it go by all day! :ROFLMAO:
It has a max 4 and TP 5870 750 kv with Cardinal Racing tires. Front and rear Diffs 500k, the center is not a diff but some type of spool gear? It uses a pinion I had never seen before. Iirc it's called a bell clutch pinion. Definitely not many options around for that :ROFLMAO:
Sweet ride man.
That pinion sounds like a nitro style of pinion. Those use a centrifugal clutch (often aluminum pads).
Not sure if that's what you got there 🤔
Very nice sir! Eager to see your speeds. 💪🏼
