My 14T pinion gear continues to slip off the motor shaft. I've tried just about everything and would appreciate any tips for how to solve. Rig and mounting below. I appreciate your time.
RC Car
Installation
I've purchased a new Arrma 14T Mod1, but want to check before making the same mistake.
Thanks
RC Car
- Arrma Typhon v4 6S
- ESC: Hobbywing EZRUN Combo MAX6 Series
- Motor: Hobbywing 4985, 1650kv
- Pinion: Original stock 14T
- Tires: Duratrax Lockup C2
Installation
- Cleaned motor and grub screw with rubbing alcohol
- Locktite Blue, applied to grub screw on pinion
- Grub screw tightened using Vanquish hex drivers (which are amazing by the way)
- Hobbywing motor only has one flat side, so single grub screw was used on the pinion
- Attempt #1: Tight mesh - pinion slipped after 15 minutes. Pinion gear was okay. Spur gear was okay.
- Attempt #2: "Normal" mesh tightness. Sanded bottom of grub screw to ensure it made perfect contact with the flat end of motor. Pinion slipped after 10 minutes. Pinion gear was destroyed. Spur gear looks completely fine. Pictures attached.
Thanks
