Erikfireplaces
Im trying to figure out how to mount my spektrum 120 esc but it seems way to big. Anyone out there done this or maybe steer me in right direction? Beginning of BRCCv3 3 to 4S conversation
Its just to wide! I didn't know if there was a bracket or piece of plastic that helps hold itTbh I'm not familiar with the spektrum esc whether it's any different to the blx but I found when it was mounted on top of the receiver box it was prone to getting mashed as it was close to the body work.
So I fitted my new max 10sct in the space between the receiver box and the motor on the chassis. As it happens there are 2 holes in there just for doing so.
It's a damn site safe there
This exactly how I have mine on my senton if that helps only way to really get it on there without custom mount.Its just to wide! I didn't know if there was a bracket or piece of plastic that helps hold it
The 150a esc doesn't fit in thst spot I just checked. Would have been nice though.Tbh I'm not familiar with the spektrum esc whether it's any different to the blx but I found when it was mounted on top of the receiver box it was prone to getting mashed as it was close to the body work.
Well if you ever decide to trade up to the 150 at least you know it will go in there.Ah yes, I thought the 150A would be to big for the space there, so I stuck with the 120. I know, I know I wimped out
Thanks man, so you just used tape to secure it? Also what shock did you find that fit?id like some of those. I have had so many issues with shocks Ive been through 4 front shock and haven't had truck since February. 1 last thing how well fo those braces work for you? Can you adjust the height or stance of truckWell if you ever decide to trade up to the 150 at least you know it will go in there.
Ok so I put one screw in one the side that is close to the center of the car and used esc tape from my lhs and the shocks I got off ebay they are the typhon 6s shocks with the 3s conversion springs Jenny's rc like 50 bucks for the front 50 for the rearThanks man, so you just used tape to secure it? Also what shock did you find that fit?id like some of those. I have had so many issues with shocks Ive been through 4 front shock and haven't had truck since February. 1 last thing how well fo those braces work for you? Can you adjust the height or stance of truck
What motor are you running? Do you not need a heat sink and fan with these motorsIts just to wide! I didn't know if there was a bracket or piece of plastic that helps hold it
Looks good. Looks like you bent the motor wires downward to connect to the esc wires. Is that the stock 3s motor? I’m trying to figure out what to do with my wires since putting in the 150a esc. Right now they’re too high for me to mount the body
