1515 2200kv question
WTF MIKE
I noticed that the shaft in motor moves in and out quite a bit. I also noticed the end caps are pushed out a bit. I want to know if this is normal before I send it in for warranty
I just checked mine. It has about the same amount of play. It runs fine though. Motor is approximately 14 months old.
Wow good to know thank you. Mine springs back as well. Did you notice if your end caps are pushed out a bit? Mine are just a bit
Just heard from castle they say it’s not normal. They want me to open it up to see if a shim is missing
