I've got a 20, 23, 12, 15, 19 and a 33 which is way to big. What size are people running with good temps? I've got a dual fan setup for it.
Also only using 6s batteries.
Sorry my bad, KratonWhat type of vehicle? In my infraction 26, if in my kraton a 18.
But that'll be to big with my 500,000t spur gear760,000 tooth pinion![]()
Thank you. I really need to order one of those temp guns.I would try 20t first. With a heatsink and fan, you would bump up to 21 or 22 but start with 20. It might even get hot on 20 so keep an eye out and have a ir temp gun on hand
That's pretty much what I'm doing when I get the time to do it. I haven't found any areas that have the type of landscape to do jumps off.I'm running 23t on castle 1650kv. Never gets hot enough to worry. But I don't do stunts. I just run around on grass and mid jumps or mainly street use.
I'm also running this on castle 1717 1650I'm running 23t on castle 1650kv. Never gets hot enough to worry. But I don't do stunts. I just run around on grass and mid jumps or mainly street use.
We all are doing only two screws into the motor through the motor mount. Only have those two you can get to. Kraton, Infraction, Felony, etc. Threadlock them and screw them down good you will be good.I've just picked up this motor and realised when putting it in that there is only provision for 2 bolts into the motor. The manual for the motor suggests 4.
Is there a motor mount that allows 4 holes to be used to mount the motor instead of 2 via the stock slider setup?
Meh, just don't read the manual then.I've just picked up this motor and realised when putting it in that there is only provision for 2 bolts into the motor. The manual for the motor suggests 4.
