Hey,
I hooked a new Taurus Rocket 1700kv sensored motor up to the SkyRc Ts150competition ESC to run in my Big Rock and have some problems.
- After like 10 seconds of half throttle cables are really hot, motor starts getting hot.
- Also one weird thing; with sensor cable connected it will rev much higher then without.
I am not sure if I forgot a shim on one side of the motor when I took a look inside, solder joints seem to be okay, and I run the exact same combo in my Kraton without any heat whatsoever.
However I did notice two things while disassembling:
- Strator /windings has one spot where I'm not sure if that could cause a short of some kind (pic)
- Rotor is a bit scratched up from some burr that was inside - should be all clean now.
I use 4mm plugs, once I connected ESC wrong and some sparks flew, one of the connectors is kind of dull ever since.
So, the motor runs, but gets super hot super fast & revs much higher with sensor cable plugged in.
Also, it sounds a bit as if it's running under water (never seen water).
Anyone has an idea what could be wrong? Could the 4mm plugs be too small? Motor draws 95amps...
Any help would be greatly appreciated!
