ksearyback
- BigRock 4x4
- Granite
- Thread starter
- #21
I understand what you're saying. I should probably rephrase slightly to say that I actually have made purchased for a specific reason and with a plan to see if I could do it.Word of advice. Don't do this. Only upgrade when you have a specific goal. This forum recommends unending upgrades, but almost never asks what you want to accomplish. Not all recommendations will improve the way you drive, some may make things worse. I made the mistake of listening to too many consensus "upgrades". Many ended up being downgrades and I've gone back to stock.
But this forum is useful if you ask for upgrades for a specific purpose. So, before you upgrade. Why do you want different tires? What are you looking to improve? If you find yourself sliding and spinning the tires too much, MX28's will improve traction over the stock tires. I run MX28's. They are especially good if you run in loose dirt. But as Jerry Rigged pointed out, they are heavier, they will stress driveshafts more and make your RC overheat faster. Also, increased traction is not always a good thing. It will make you traction roll more when turning, especially on high traction surfaces like pavement or grass. If you are already rolling over too much, the MX28's will make it worse, the stock tires will slide turns more easily.
We have two Granites.
Truck #1 - One of them broke a front A-arm, so I replaced that with the RPM made for the Granite. I accidentally bought two packages of them, so now I have a spare set, which will probably be returned. The servo just went out so I just ordered a new one for both trucks, and I also got whatever the cheap piece is I was told needed to be included because it had to be a 25T (I have no idea what that means, but I bought it). Turns out the 25T may have still been the wrong part, so now I will have 4 of the things the come with putting in a new servo.
Truck #2 - Because my son rolls the truck a decent amount, and kind of just for the fun of comparison, I decided to buy all the parts to expand the base with the longer a arms, so those are added to my box of things. I had conflicting information from well-followed YouTube folks who just modified with the longer a arms and then went with the 17mm hex and new tires. Others said I absolutely had to also buy wheel axles, wheel nuts, turnbuckles, and 2.5mm pins. Later I believed I made a mistake by not getting the 17mm hex offset hubs, so I bought those too.... finally I went to order the badlands tires when I finally understood they could adjust to 17mm only to find out they only had one set remaining on Amazon, so the other two are back-ordered. A day later, in this thread, I was informed that I could buy the M2 adapters and don't even need all the 17mm gear (although this part remains confusing to me).
So yeah, long story, with lots of parts ordered, but they were intended to be part of a relatively simple plan. I can send most of the stuff back once I figure out what I actually need.
