ksearyback
- BigRock 4x4
- Granite
- Thread starter
- #41
Perfect. I got the hex off. Do I keep the pin in with the adapter? The pin doesn't seem to have a natural fit to the adapter, so I assume it's not needed unless I put the original hex back on, was that why you said not to lose it?The m2c adapters add 13mm of width over a standard stetup. Grab a 1.5mm Allen and loosen the set screw. Slowly pull the hex off and be careful not to lose the pin.
Edit: Ignore that question. I see the fit now! Much appreciated for this help
