TwinTurbo95
While bashing my one of the 2 screws that holds the front T-Bone bumper to the bottom of the chassis broke off inside. What tools you guys use to back it out?
You need one of these. https://www.amazon.com/Ontel-SpeedOut-Damaged-Screw-Extractor/dp/B00IRL3WP4
That should have been a 2.5mm ???It's this one right here...
Thank you...You need one of these. https://www.amazon.com/Ontel-SpeedOut-Damaged-Screw-Extractor/dp/B00IRL3WP4
Not.in his condition buried in the skid plate... I 2nd the lefthand drill bit option... For this situation anyway.Try to use Dremel to cut across the scew and then used a flat screwdriver to turn the screw if that work or not. Usually that work for me.
