THanks ,
Schuey
You are basically running 6S because the connections are in series. Run time I do not believe you "extend" it since they are in said series set up so they are treated as 1 single 6S battery @ 4300 mAH. I have ran a single 3S pack, not sure if it is recommended (I only see 4S/ 1-4S OR 2- 2S/ 2-3S OR 1-6S in the "upgrade" speed sheet) though for a test run on my Typhon. It might kill a battery pack though doing this maybe.......not sure and I am not going to run it again that way anyway.
AFA the power shot...no clue, I used an air compressor and blow out most of the leaf and debris collection and give it a shower, once again to the air compressor to dry.
Re-charging batteries- Good question I would also like to know the answer myself. I have not had enough time to kill the batteries in a single run since it is cold and crappy here in the last week.
Found this looking around about running 1 3S battery, although Typhon it still applies to the Senton:
https://arrmaforum.com/threads/is-it-safe-to-run-a-single-3s-lipo-in-the-typhon.881/
I was told by people in another forum i belong to to never let rhe batteries die go get a lipo battery checker.. Venom Power dot com sell them for like 10 bucks you can hook them up to the balance cable and when the alarm sounds usually between 3.3 to 3.6 you know its time to recharge.. everything ive read says draining lipos kill them. This is what another person told me--You aren't supposed to run LiPO's until they die that's a good way to ruin the battery. The esc should have a voltage cut off in LIPO mode. 3.5/3.6V per cell is the minimum a cell should be discharged to.Most of us run those lipo checkers that do a super loud alarm that lets you know you hit the threshold.. these batteries are too pricey to burn up fast..
Im not sure what part of the world you are in but i feel ya on the cold..
Schuey
Yes, 2/ 3S (6S) total is fasssssssttttttttttttt. I was shocked myself when I hit the trigger and it was goneeeeeeeeeeeeeeee. LOL
Waterproof electronics= Yes, as far as a car wash I would believe it's OK.(I've given it a bath in the shower too) I just wouldn't use the high pressure myself, I used ours at work to rinse mine off and blew it off with compressed air. WD-40 on the shafts and bearings and steering etc. etc. etc., then used oil to lube those parts back up. Runs fine for me!!!
I already changed out my tires for Pro-line Trenchers, hook up much better for a few quick shots across the road way is all I have done. Too cold here to run long though ~ 25-30*F today.
I had an idea today to get me a 55 gal garbage can like what i have in my kitchen..( 4 adults 1 kid lives in my house ) and i figured i would take the lid into the shower and hose down the senton and let the mud fall into the lid and then let it dry and then throw it away.i have a septic system and tbh im not sure if i should be shooting dirt down my drain.. i would assume its fine since its going to break down faster then poo but im having it pumped this friday ill have to ask the guy for his opinion.
Lawn + hose = Nero cleaning station
Weather the same here, I'm west of you in IL. Thunderstorm early this AM though. I have placed mine in the pits too, itching to run a full battery pack one of these days LOL I want to go to the park up the street and run the snot out of it but like you, the weather in not cooperating!!!
Have you replaced your tires ? i bought some Pro Line street tires and whoa.. they are different then what im used too the front is smaller then the outer weird to me.. trying to find some Senton tire mounting videos but only on the monster trucks have i found them.I see all these ppl talking about taping tires and using belted tires.. crazy.. stuff.. we didnt do this in the 80s 90s..
