2.8 Badlands for my Typhon
bicketybam
Resident Sweetheart
ArrmaForum Fan
New Milford, CT
Granite, Kraton, Senton, Typhon, 4x4-Mega, Notorious, BigRock 4x4
Should I ditch the wheel extenders? Doesn’t seem like clearance would be an issue. This is with the wheel extenders:
B7CD4A63-4744-4D83-A2C1-8A151C651D55.jpeg ABEDC336-36B7-4B70-9C14-09379743E07B.jpeg AD8B8D99-F48F-4DAC-B0E7-717B4BF6F69B.jpeg
TooTall
ArrmaForum Fan
Kraton, Nero, Talion, Typhon, 4x4-Mega, Notorious
Extenders are required, I tried the same on my Typhon without and they will catch the body when turning under power and they balloon.
It makes a horrible noise when it does too :)
TT
edit: or are those Hot racing hubs actually Kraton hubs and axles? If so, then the extenders wouldn't be required.
bicketybam
Resident Sweetheart
ArrmaForum Fan
New Milford, CT
TT
I have HR hubs on my Kraton and these are different. They are flat whereas the Kraton ones extend a bit. At one point the ones on my Typhon fit the Kraton, but it must have been V1. I actually ordered the ones on my Typhon for my Kraton in error and they did not fit. I never checked the cross reference on HR’s website.
TooTall
ArrmaForum Fan
ok if they are flat, then they are most likely the ones from Typhon, so then the extenders woudl probably be required.
TT
bicketybam
Resident Sweetheart
ArrmaForum Fan
New Milford, CT
Well the Badlands are everything as advertised in the dirt and grass. They will actually strip the grass if I'm not careful. They do balloon a lot though. I'm going to use some fishing braid on the front tires and see how that helps. The Typhon is so frickin fast. It makes my Kraton seem slow.
WTF MIKE
Outcast
Change your diff fluids they will help the front tires from ballooning a lot. And braid them after if they still balloon alot
bicketybam
Resident Sweetheart
ArrmaForum Fan
New Milford, CT
I decided to shim my diffs this morning so I went and changed the fluid. I had been running 30k in the center. Now it is 500k. I went with 100k in the front and 50k in the rear. It’s raining so I won’t be able to test it until tomorrow.
bluedeval03
ArrmaForum Fan
Danville KY
Have you run it yet???
bicketybam
Resident Sweetheart
ArrmaForum Fan
New Milford, CT
It’s rained every day since. I’m charging batteries now and I’m going to see how badly they ballon. I will report back in a bit.
WTF MIKE
Outcast
Come on you have to do the rain dance and post it on here
Chilly
BigRock, Fazon, Kraton, Nero, Outcast, Talion, Typhon
2BF18409-FDF5-4636-B2A4-0C030A30D592.jpeg E024256C-06FC-4B75-8AA4-F066F8218D10.jpeg 8C1733C9-F094-4142-AC59-74248815141C.jpeg Use kraton hubs on typhon instead of extenders works great
Chilly
8D3ADCCC-C06F-41C5-A40E-ABF4B194216D.png I also use talion shocks on my typhon front are same size back are just little bit longer works great for bashing
Chilly
I also tap my tires and use rpm 3.2 rims
Chilly
Lol no must be the picture I have kraton front and rear same width front and back
bluedeval03
ArrmaForum Fan
Danville KY
okm was making sure before I ordered. I was looking at the Kraton/oucast and notice how much wider they were. Now did you have to change the axle stub, or not?
Chilly
Yes you have to change them weel nuts everything you can order set from Jennys rc axle 30 bucks full set weel nuts 8 bucks full set and kraton or outcast hubs 14 full set or kraton 20 set some times there out of one or the other but jrc is cheap they also sell on eBay my typhon handles way better now
Similar threads
