Kraton 2 Grub Screws or 1 on Speed Gear? Kraton
AustinKraton
Hey Guys,
I noticed the original stock pinion has only one hole for a grub screw.
The speed gear has 2.
Should I use the supplied grub screw plus the original in the speed gear? (i.e., 2 grub screws - one for each hole)?
Or just 1?
If the motor shaft has 2 flat sides you can use 2...but most motors only have 1 flat side on shaft...therefore only 1 grub screw is needed with blue locktite
This is a V3 Kraton with BLX motor that has 2 flat sides.
They are now in the V4 version.
