Does anyone have any of the 2 mm spacers that go in between the top arm to keep it from moving?
These? https://www.amainhobbies.com/arrma-...nQdSLxG_NgCHiBMFK2fTrTHMz458-GVRoCe1gQAvD_BwEDoes anyone have any of the 2 mm spacers that go in between the top arm to keep it from moving?
These are for the nero.. you sure they'll fit the 6s? not sure that the hinge pin is the same size
link to the specific thing you are talking about?Home depot has them
That's what I use on mine, they fit like a rubber glove built for 1 and they even include spacers for the pillow balls.These are for the nero.. you sure they'll fit the 6s? not sure that the hinge pin is the same size
The 6s version cannot be bought separatly, you need to get them together with the upper arms.
I don't have a link but if you go to the hardware section they have drawers of specialty items and they have all kinds of different nylon washerslink to the specific thing you are talking about?
Ok, I will go to home depot on Sunday.I just bought a bunch of nylon washers. Not that difficult to install instead. Lost too many clips.
Would you be willing to print some?Can always 3d print them.. that's what I do.. I have piles of them.. if you need some printed let me know..
Another option is to cut them yourself out of Tupperware totes or any plastic that's not super brittle..
Just 2mm, both of my original ones broke.No problem at all.... do you want just the 2mm shims? Or both 1 and 2?
