Hi guys,
I understand why electric cars have no multispeed gearbox; because the torque band is linear and there is no peak torque/RPM like there is in traditional gas engines.
However, would it not be beneficial to have a 2-speed gearbox in my Talion? Then I wouldn't need to worry so much about what pinion to run. I could run a large pinion on all terrain, as the 1st gear in the 2-speed gearbox will reduce the strain on the motor, until the vehicle is up to speed where it'll shift into the second gear to achieve greater top speed. This would keep the motor and esc heat down by not straining it at low RPM. Am I missing something?
