Raider 2013 Arrma Fury diff parts questions.
biggman100
Fury, 4x4-Mega
I have actually been looking into this for quite awhile. I have a 2013 spec Fury, that is constantly having diff issues, and i have seen posts about upgrading to the 2014 diff, but, cant find a couple of the parts, so, i started looking into the composite diff swap, but, i am not sure if i have all the necessary parts on the list i made. Here is what i have on the list:
AR310597-0.8M COMPOSITE GEAR SET, AR310600-INPUT SHAFT 60.5MM (PLASTIC MOTORPLATE GEARBOX), AR310601-0.8M GEARBOX SET (PLASTIC MOTORPLATE), AR310762-METAL INPUT SHAFT GEAR 15T 0.8MOD (1PC) If i need anything else, let me know.
Since it is brushless, with a Castle Sidewinder SCT, im not sure how well the composite gears would hold up though.
I was trying to swap to the 2014 diff, using these parts:
AR310001 Gearbox Set Granite Raider, AR310016 Idler Gear 20T Metal, AR310599 Input Shaft 59mm BLX 2014, AR320007 Motor Mount Plate Raider Fury Vorteks Granite Mojave, AR310378 Differential Gear Maintenance Set : Raider / Fury and Vorteks BLX, and AR310416-48P METAL GEAR SET, but, i cant find the AR310416 anywhere.
I want to try and save my Fury as long as possible, but, just this year alone, i have had issues with either the spacers getting coned, or, on this last one, the one gear shattered, the pin broke, and the output broke the end off when it all locked up. It has happened 5 times just this year, but, it is the only good 2WD i have, and, since i like that truck, id like to try and keep it running if possible. I still have 3 complete 2013 diff's, so, another idea i had was just replace the washers behind the gears that attach to the outdrives with something thicker (the ones that keep getting coned. Ihave 3 good diffs, all with that same problem), but, so far, i haven't found anything that will work, so, any ideas there would be greatly appreciated. I have tried everything from 10K-50K diff oil, and had the slipper pretty loose, and it still does it. I just don't want to replace it with another truck, if i can keep it working.
biggman100
Fury, 4x4-Mega
I did find these shims, that from a video i watched, said they would work better than the stock ones: Xray washer s 5x15x0.3 10 XRA964050 Has anyone tried them, and did they work?
Create account
Log in
N Granite Buying used 2013 model Discontinued Models 14
LunchBox WTB 2015/2013 Granite BLX parts Classifieds 0
S 2013 mojave Discontinued Models 1
mrbelloso 2013 Upgrades Discontinued Models 5
Similar threads
