Premium members don't see ads. Click here to upgrade.
Granite 2018 Granite 4x4 BLX Steering Issues.
Texan45
Can’t get Granite to steer straight. Only two runs out of the box. Servo centered, trims adjusted. Is there a serious slop issue with this model?
bicketybam
Pathetic guy with a GoPro on his head
ArrmaForum Fan
New Milford, CT
Granite, , Talion, , Notorious, BigRock 4x4
Depends on how straight you want it. Hands off the wheel, track dead straight, straight? Not happening. But I can line it up at decent speed with a pretty narrow ramp, so it’s not like it’s uncontrollable. The steering assembly is pretty straight forward. There are 4 bushings you can replace with bearings that will help. Check to make sure the servo saver/horn is tight. Feel around for other outrageous play. I say outrageous because there will always be play in the plastic steering assembly.
Texan45
Ok, I will check those out. Thank you Bicketybam for your response.
Similar threads
