I believe so yes. I’ve never contemplated it but that makes sense to me.What's the advantage of the capacitors? Smoothing it out or?
You bought a 4x4 off road buggy for pavement? Seems odd to me but hey /But for ME I only drive on pavement/non wet conditions.
Funny, I recommended someone else to try this in another thread. Looks like it works pretty well. Are you able to flip just the ESC and keep the receiver box lid/power switch in the stock position?I just flipped the whole ESC to the other direction.
There is no hole for the screw that holds the power switch down on the other side of the receiver lid, and the wire for the power switch is just a bit to short to reach with the esc flipped and the lid in stock position. Honestly If could solder i was just cut the cap pack out, run the wires backwards along side the esc then solder the cap pack in behind the esc.Funny, I recommended someone else to try this in another thread. Looks like it works pretty well. Are you able to flip just the ESC and keep the receiver box lid/power switch in the stock position?
Perfect!Edit: Made a change to setup, esc flipped backwards, receiver lid on the stock way, moved the power switch to and unused screw hole using stock screw, as seen in pic. Can easily reach under side of body with it clipped on to turn on car.
Wasn't that one of the first fixes for the esc that kept bursting into flames on the XMaxx? Didn't they sent you a battery lead with a cap pack in it?When a manufacturer provides capacitors with an esc out of the factory, they’re usually doing it to hide an issue. Very important part on the esc.
Nah, they put in a fusable link, so when it caught on fire, it would go out pretty quick ??Wasn't that one of the first fixes for the esc that kept bursting into flames on the XMaxx? Didn't they sent you a battery lead with a cap pack in it?
