You need a ground loop isolation. Something like this will help a lotI run fpv in my rig though and that's why I wanted a cap pack to help clean up my signal. I tried a single cap but no luck and was told paralel setup might help. My fans and buck convertors make a ton of noise and I still see lightening bolts in my goggles and onboard dvr.
I think you are getting excited and keep forgetting about the rule.No, I am not trying to double-dip. lol
That's exactly it! Or MAYBE I didnt read them. (I did read them)I think you are getting excited and keep forgetting about the rule.
okay well thank you anyways. I'll just end up making one then. I still have to order a cpl more caps.
Caps won't help as much as the isolator. I would say do both but you don't need more then a few thousand of tops.okay well thank you anyways. I'll just end up making one then. I still have to order a cpl more caps.
I have a few glitch busters you can haveokay well thank you anyways. I'll just end up making one then. I still have to order a cpl more caps.
I have a cpl 1000uf panasonic ultra low esr caps but the legs are all mangled from me trying to run one in each car without luck, I think my fans and buck convertors suck up the cap before the fpv vtx gets the power if that makes sense. When I turn off my power switch the vtx shuts off instantly almost as if the cap doesn't hold juice at all. I trust what you say. Where can I get this ground loop you speak of, been looking on amazon I need two one for each rig. Btw my vtx is powered by a buck covertor (one of three in my rig) the other two control my esc and motor fans(stupid high amp draw on those fans). I have lights and underglow running off my receiver so I didn't want to run the vtx power off it incase it draws too much and burns out my receiver.Caps won't help as much as the isolator. I would say do both but you don't need more then a few thousand of tops.
You will need 1 for each powered device unless they all run on same power leg. Let me see what I can find. I normally make my ownI have a cpl 1000uf panasonic ultra low esr caps but the legs are all mangled from me trying to run one in each car without luck, I think my fans and buck convertors suck up the cap before the fpv vtx gets the power if that makes sense. When I turn off my power switch the vtx shuts off instantly almost as if the cap doesn't hold juice at all. I trust what you say. Where can I get this ground loop you speak of, been looking on amazon I need two one for each rig.
all three convertors are wired together like the picture direct off the battery. Srry for the crayon drawing.You will need 1 for each powered device unless they all run on same power leg. Let me see what I can find. I normally make my own
Fixing FPV Video Issues - Noise, VTX Connection, Power Filtering - Oscar Liang https://oscarliang.com/connect-vtx-fpv-camera/all three convertors are wired together like the picture direct off the battery. Srry for the crayon drawing.
What are they for?I have a set of front and rear Integy aluminium a arms in orange. For speed runs or shelf queens only. They are used and got some good scratches but they are collecting dust and could be used by someone maybe. You pay post and they are yours.
Kraton and Outcast 6s.What are they for?
@Camaroboy383 i wanted to tell you thank you again. I also enjoyed the pm's. This is what makes arrma forum a very good site!? Friends and fellowship?I still have to go digging to make a list but I will start off with these couple things..
1) (GIFTED TO TRIGGER HAPPY) Amazon 20kg servo brand new in box, not the fastest but they work..great for a crawler.. FREE SHIPPING IN THE US (GIFTED TO TRIGGERHAPPY)
2) new Robinson racing hardened 20t 32p 1/8" bore... FREE SHIPPING IN US
3) Outcast/ Kraton factory a-arm set complete new set, no turnbuckles.. FREE SHIPPING IN THE US
