Do not attempt to use this motor again.
Yeah its done the poke doesn't really matter theres no wire next to it to touch. It overheated 2 time my previous esc? i had a feelig my esc would burst on fire ima still test the motor at my hobbyshopDo not attempt to use this motor again.
That would be unwise. That motor is toast and will potentially break the ESC that you connect.I ran it with a 12t and 14t maybe it was defective out of the factory and burned up. I have no words. I will still test it out at my hobbyshop
I didnt say i would run it. I just want to be sure at 100% before i buy a new oneThat would be unwise. That motor is toast and will potentially break the ESC that you connect.
Not even sure why you would do this, it's dead and won't come back. Even if for some miracle it works without a load it's a piece of junk and should never be used again.
Throw it away and move on, hopefully it didn't damage your ESC already.
I hope it didnt i have 2 escs nowThat would be unwise. That motor is toast and will potentially break the ESC that you connect.
No i mean that black ring just above where the front bearing sits on.Black 'ring' on top of the shaft?
Holds a c-clip to prevent the pinion from flying off if it comes loose.
New with the safe-D pinions from Arrma. My c-clip flew off but probably goofed on the install, go figure . Pinion stayed just fine .
I ordered the firma motor but i just noticed the spare parts i have are now useless specially the rotor i doubt they are copy paste motorNo idea what that is, can't tell if it's on mine but don't believe it is. Maybe just a spacer.
