I do. Will be back in town tomorrow. If you order one I will ship it out first thing Friday morning with tracking. And yes a major upgrade for sure.Looks like this would be a good upgrade for my V4 Kraton? Do you have any left?
Thank you sir. Will have an email out to you Friday morning with tracking info in it.Great, money sent! Thank you sir!
I got it will get it out in the morning. Thank you.Thank dave. I just order 2 servos from you
Yeah it’s a good upgradeDo you have any more available? Would this work on my Outcast 6s 2019 version?
I d ont re use anything but the screws. Remember to use some loctite.So when I am replacing my factory servo for this, I am also switching to an Armor Werks one piece servo mount, Do I screw the new servo directly to the servo mount, or should I reuse the factory rubber and brass bushings? If I do use the factory rubber and brass bushings, the top of the servo appears to be quite a bit higher than the stock set up...?
@Rott, thanks for asking because I was having issues getting things lined up and just used the stock servo arm for the time being. I was going to reach out to @arrmadand ask your same questions but haven't had a chance.
Yes, use the stock servo arm until you can get another set up. Something like this, https://www.amainhobbies.com/hot-ra...steering-w-25t-servo-arm-hraaon48sh25/p702009@Rott, thanks for asking because I was having issues getting things lined up and just used the stock servo arm for the time being. I was going to reach out to @arrmadand ask your same questions but haven't had a chance.
