Tgambob
- Outcast 6s
Do they have the 12.9s back in stock yet? I haven't looked in a while but last time they only had 10.9sAmazon has some pretty good deals for quality M3 & M4 hardware if you have multiple 6s rigs and go through a lot of screws.
top left container holds a few JRC screw kits for the oddball Arrma specific stuff and the other containers come in handy when building custom setups and replacing worn chassis screws
Isn’t Arrma stock screws 10.9 anyways? I was lucky to get the 12.9 screws but it isn’t like 10.9 would be the end of the world.Do they have the 12.9s back in stock yet? I haven't looked in a while but last time they only had 10.9s
3s and 4s models yes, 6s models are all 12.9.Isn’t Arrma stock screws 10.9 anyways? I was lucky to get the 12.9 screws but it isn’t like 10.9 would be the end of the world.
Was unaware. Good to know. Does Arrma have a way to know? Similar to their size relative part numbers?3s and 4s models yes, 6s models are all 12.9.
The last 2 digits of the arrma part number for screws are the length it seems if you check out the chart o have at the top you can see the there is a pattern. There is a sheet for each arrma kit number (so even for outcast there are different sheets because they make a new one for body color even) that you can compare. Looks like 12.9 is 6sWas unaware. Good to know. Does Arrma have a way to know? Similar to their size relative part numbers?
