northeastflyer
live free or die
- Kraton 6s
- Talion
3 Weeks of ownership.
Terrain:
Broken:
not installed yet:
Terrain:
- driveway / yard
- grass
- sandpits with decent air - broke servo here.
- baseball field
- parking lots / grass w huge asphalt chunks lurking
Broken:
- Shock Ends x2
- Tierod End x1
- Stock Servo
- Pulled out a pivot ball. Screwed back in. This recently happened a couple times however less sever though. The long pin/screw that goes through the front arm came almost out, and the arm I believe was jumping around a bit causing it pull on the pivot balls.
- Broken stock wing mount.
- bent rear shock tower
- Hot Racing Front and Rear Chassis Hot racing
- hot racing servo mount
- hot racing servo arm
- Digital 25kg servo
- Hot racing wheel nuts
- hot racing front steering blocks
- m2c racing rear shock tower
- rpm rear skid plate
- rpm front bumper
- tx: dxc5
- rx: 6100AT - y’all know how rookie my bind story has been. but it’s workin!
not installed yet:
- hot racing rear hubs
- rpm a arms front and rear
- rpm a arm mud guard
- also have the rear lower front and rear lower rear hot racing mounts but was going to return them for m2c might just keep them though.
