bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
There has been a lot written about the 32P spur conversion and unfortunately the info is spread out in several different threads. To make things even more confusing, the procedure/parts have been updated several times. Maybe we can make this the "official" 32P spur gear conversion thread and keep the information current. Jerry is the man when it comes to this conversion and he would probably be the best one to document it. But I will give it a start.
What you will need - Parts List
(1) Axial Spur Gear 32P 56T: https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXEEYT&P=6
(1) Axial Aluminum Slipper Pad 32.8x15.2x1mm https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXERNV (I tried the Axial fiber pads and they could not handle 3s power. They did hold up fine on 2s. https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXEEYW)
(1) Arrma Pinion Gear 32DP 17T https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXDUPS&P=6
(2) 10x15x4mm ball bearings https://www.amazon.com/gp/product/B003KSNXU8?tag=arrma-20&creativeASIN=B003KSNXU8 These can be sourced at your LHS as well. I actually used bearings that I replaced on my Granite. The inner race from these bearings are used as an insert on the Axial Spur and as a spring spacer on the completed project.
(1) M10 washer - an M10 washer has an inside diameter of 10.5mm and an outside diameter of 20mm. YOu can buy these at any hardware store of Home Depot.
If someone else wants to write up the step by step, feel free. If not, I can give it a go later on.
