- Location
- Southeast, MI.
- BigRock 4x4
- Granite
- Senton 6s
- Typhon 3s
When I first got mine one cut out at 4V per cell Senton, and 3.85 on granite, did reset and they stayed the same. Just did reset again, on Senton/big rock now, 4th time and it worked to 3.5 vpc but lost reverse, recalibrated radio and still couldn’t get reverse. I do have several hobbywing programming cards from my crawlers and it showed reverse was selected. Did reset again and got reverse working but it now cuts out at 3.8 vpc. Ran a couple packs through each time. All test were with power hobby 3s 5000mah 50 c batteries running 2 in parallel xt60 to ec5 y adapter 10 gauge wire, they run down to 3.5 vpc in my other 3s blx just fine. Did not try resetting granite again as it will only use 2s for a while, might try again sometime later. 2 of the trucks I have are for my kids so 2 s is plenty.
Definitely issues that you may get a lucky reset and the stars will align and everything works.
If at first you don’t succeed, try try again.
