burgerking
It was going really good until it started doing fwd burnouts
View attachment 152804View attachment 152805
Ill give it a goCan you bend the plastic and put the metal back in the proper spot?
What screw?Slipper clutch got tight on you maybe. Have u thread lockes that screw?
You can do that. but. it will be severely wakened from its original state and will continue breaking. Better off to buy a new axle IMOCan you bend the plastic and put the metal back in the proper spot?
Ill give it a go
What screw?
Small problem, ordered new shafts and my hex driver does not fitReplace it will come back out the plastic is weakened.... as stated earlier something it too tight check the slipper.
Small problem, ordered new shafts and my hex driver does not fit View attachment 153085
It is too wide most likely and doesnāt fit through the axleHi..
don't understand when you say it does not fit it. Explain...stripped or something like that?
Driver is too fat for the hole, will try a different one when I get homeHi..
