- Richmond, VA
- BigRock 4x4
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave EXB
- Outcast 6s
- Outcast 4s
- Talion
- Typhon 3s
- Vorteks
Has anyone also had issues with the internal gears of their 3s/4s cars stripping? I've gone through about 3 in my Kraton 4s, and it's just getting ridiculous. Lately I've only run the car on 3S thinking it would be gentler but nope. I'm running the Arrma metal diffs and input gears with the composite body. Also has happened to me running the HR diffs. It seems like the bottom metal diff outdrive, opposite the side of the ring gear always shifts up too much, which causes it to cram into one of the lower two diff planet gears. Then that outdrive loses teeth and causes the whole diff to seize up. See pic below.
I feel like this has to be user error on my end, or just a secret I'm not aware of, like internally shimming these diffs so there's no play and no chance of all the gears inside colliding with each other. I run the diffs with the gaskets, and shim the outside. I don't feel like theres much else to it that could be messed up. Once I rebuild each diff it works perfectly fine, its oly after about 3-4 runs that I notice the diff gears inside have been eaten all up.
Anyone else have this problem??
