Average driving 30 minutes. Pedal to the metal off-road driving 10 minutes.
This is exactly what I get.My Typhon 3S on a 5000 50c is easily 45mins on a mixture of 75 & 100% throttle. My first run with a lot of 50% ramp jumping was well over an hour with stop start, photos etc etc
At 50%, it runs about 10 minutes on road, maybe 12-14 minutes if I don't push it. Its only running back and forth, I barely get to rip it, no place to send it or jumps near by.Average driving 30 minutes. Pedal to the metal off-road driving 10
That's weird. What battery and what rig are you running?At 50%, it runs about 10 minutes on road, maybe 12-14 minutes if I don't push it. Its only running back and forth, I barely get to rip it, no place to send it or jumps near by.
And from your post I'm guessing it's a 5200mah? What gearing are you using? That's suspiciously low for that battery capacityLectron battery. Vorteks. Could it be low voltage pack?
Its the stock one with the new vorteks 4x4 3s blx, I haven't used the other one that came with it. My other 2 vehicles runs fine with their own type of batteries.And from your post I'm guessing it's a 5200mah? What gearing are you using? That's suspiciously low for that battery capacity
I've heard there's a rampant issue with the arrma escs cutting off too soon. Maybe get a voltage tracker and run it in NiMH mode?Its the stock one with the new vorteks 4x4 3s blx, I haven't used the other one that came with it. My other 2 vehicles runs fine with their own type of batteries.
Voltage checker for the battery pack, is it the lipo checker or it that diff?I've heard there's a rampant issue with the arrma escs cutting off too soon. Maybe get a voltage tracker and run it in NiMH mode?
