Hi everyone,
2nd time running my Big Rock, I managed to run dead on into a concrete garbage can. User error. The car was amazingly fine, except the motor mount bent forward so far that the pinion was just barely contacting the spur and stripped it out. Also cracked a small portion of one half of the clutch housing where it interfaces with the rear diff. I flattened the motor mount out (a new one was not available anywhere I could find quickly), bought a new clutch housing which took a week to arrive, and put it back together and all is good. However, I'm gunshy to jump this thing now for fear of landing on the nose and bending the mount again. Wanted to see what you all thought of this idea.
The motor is heavy and sits suspended in the air from the motor mount by the two motor to motor mount bolts. In a hard front impact, I believe the motor just keeps moving forward and bends the mount since the motor isn't supported underneath or in front. I had the idea to wedge something under the motor to support it, but this wouldn't stop forward motion, had a 2nd idea to place something between the front of motor and back of ESC to prevent forward motion, but was afraid with body flex that this could actually be a bad idea and prevent some of the flex. My final idea, after recently changing the big batteries in my daughters' power scooters that use a glob of hot glue at the contacts to keep them from coming disconnected, is to put a glob of hot glue under the front of the motor. Not much, but enough to prevent it from moving up/down or forward as well in a front end collision. Hot glue is slightly flexible, and pretty easy to peel off if needed.
Any thoughts on this idea or any downside that anyone can think of? Has anyone tried something similar?
