steven pfarr
- Typhon 3s
So my typhon was running fine and I went to adjust my slipper clutch and after the car started shuttering and would not move. I took the car apart and the motor spun but wouldn't under load. The shaft wiggles a bit. Is the bearing dead? Also after taking the motor out of the car and spinning it at around 3/4 throttle it screams. So should replacing the motor bearings fix the problem? What about the shuttering?
