Senton 3s blx Senton tires
e34canon
Anyone have any suggestions on which tire I should use? I like to do 10-15ft jumps at my local bmx park. The terrain is a mixture of loose and pebbly dirt along with hard packed surfaces in some areas. I’ve gone through 4 full sets of stock tires cause they keep blowing out.. any input would be great help.
Thanks in advance
Senton sidewinders , but a conversion to 17mm is needed. There meant for the 6s truck..I use them on my 3s.
I don't want to open a new thread, so I'll just ask here:
I'm also looking for different tires. The Fortress SC keep blowing up. I found different kinds of Louise Tires preglued to the rim. But I'm still not sure if they'll fit:
Outer diameter 105mm / 10,5cm
Inner diameter 70mm / 7cm
Width 50mm / 5cm
I measured one of the original tires / rims. Outer diameter seems to be the same, but inner diameter is a little larger, something around 74mm? Also, width is only 4,5.
Will they fit or will they rub on the body because they are wider? Is the inner diameter a problem, will they rub on the steering?
Example of the one's I found with 14mm hex:
ST Uphill
