Premium members don't see ads. Click here to upgrade.
3s blx servo
Wags1
BigRock 4x4
Whats a good upgrade servo and bellcrank for a big rock 3s blx
crimsonfancy
A guy that doesn't know when to give up.
South Louisiana
Kraton, Talion, Typhon, Notorious, BigRock 4x4
Hot Racing and JX6221 imo. Is your stock servo dead? Mine still stock is fast and strong enough as it is .....even with heavier 2.8 Badlands and a little extension. Standard servo for me was almost too fast with the BRCC stock wheels and tires.
Wags1
BigRock 4x4
Not yet but wanted to upgrade. Alot of slop in the steering.
crimsonfancy
South Louisiana
Stock tires are hard to keep pointed right imo. Took me a little while to dial it in and not try oversteer compared to other trucks.
Still now I love the BRCC and run as often as all others combined. For my space where I can run the 1:10, it's fast and light,. Long wheelbase is perfect for me in this model. Works everywhere I go and it'll jump its ass off with the heavier tires.
bicketybam
Pathetic guy with a GoPro on his head
ArrmaForum Fan
New Milford, CT
Granite, Kraton, Talion, Typhon, Notorious, BigRock 4x4
You can grab an ADS-15 from JennysRC. That’s the stock servo for Arrma’s 1/8 scale rigs. They work well in the 1/10 scale trucks.
Yonic
ArrmaForum Fan
Philly, PA
Senton, Talion, Typhon, Voltage
Both the ADS-15 and the JX6221 recommendations are good, but i think it wont really fix your slop problem (but it will help with recentering). The slop is a bit from the servo saver but mostly from the pivot balls wearing and from the steering bellcrank bushings.
You can replace the bushings and use bearing instead.
You can replace the pivot balls with this set, or get fancy and get an aluminum set from hot racing.
Wags1
BigRock 4x4
6x10x3 are the replacement bearings for the bushings? They look awfully big. Is this correct?
Yonic
ArrmaForum Fan
Philly, PA
Sorry, i accidentally linked to the ones for the 6s platform. I edited the post to link to the correct (5x10x4) ones. You need 4 of them.
Wags1
BigRock 4x4
Thanks man. I thought thry looked big. Lol those r for the 3s blx big rock?
Yonic
ArrmaForum Fan
Philly, PA
Yes. For the 4x4 platform in general.
Wags1
BigRock 4x4
HThank you. I just ordered 4 bearings from Amazon, I had a 8 dollar gift certificate I haven't used.
Mk_Rc
Granite
This servo work good for me...and definitely a good upgrade 👍
306883068930690
Similar threads
