bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
I just want to confirm that the new BLX spur and slipper assembly will fit into the old Mega motor mount. I also want to correct something that I posted earlier. I stated that the new motor mount would not fit a larger can like the BLX 185. That is false. It will. The two motor mounts are very similar.
I was almost able to get the BLX 100 to fit in with the 15t pinion by using the pre-drilled 17t holes in the Mega mount. It was just a hair off. You will need to drill one of the holes a little larger and use a washer.
