- Granite
- Kraton 6s
- Vorteks
A shock shaft pulled out of the rod end on my son's Granite.
This part: https://www.arrma-rc.com/part/AR330537
I just got a replacement part, but I am wondering if it is worth trying to repair the broken one, since the shaft is perfectly straight. The shaft is only pressfitted in the plastic rod end thingy. I am thinking I could just use a small dab of superglue in there and it should work. What do you think?
I am pretty sure it will work, but I don't want this repair to be "too good". I am thinking this press fit design may be designed so that it will fail first if the shock gets over extended in a crash. If the repair hold the two parts together too well and damages something else that is more expensive, I will feel pretty dumb.
Thanks!
Thanks!
