Not an expert but I believe the top one is OK as it's a small difference. The 4.12 in the 2nd pic may be ok. Hopefully someone else with more expertise will chime in.Do these charged cell #s indicate a problem? Always balance charge with balance lead plugged in. Same with storage mode. Smc lipos. Basically brand new.
You're not dealing with a bomb, it's off some but nothing to worry about. Run it and keep monitoring it.The 4.12 reading reached 4.14 at 1 time but then dropped back down. New to lipos so just want to make sure I'm not dealing with a bomb.
That depends on the charger. What does your manual say about it?If I selected charge, would it balance charge anyway since the lead is plugged in?
Also, what's the difference between charge and balance charge? I plug the balance lead in each time anyway. If I selected charge, would it balance charge anyway since the lead is plugged in?
Appreciate all the input guys, better safe than sorry. Off to field to possibly blow a 5th tire.
Yes indeed, regarding your first paragraph, that's exactly what I do.You answered my second question as well as Tex. Thanks!For the B6AC chargers, there is a balance charge and a regular "charge" mode. If you haven't, you'll need to select balance charge in order to get it balanced out right in the end as it's charging. The regular charge mode is fairly antiquated and shouldn't really be used for lipos.
There should also be an IR measurement function. Use that to get a rough idea of how the battery health is. If one of the cells is way higher then the other, something might be up.
Won't take that chance. Always connect and balance.I would be surprised if it balanced charged, when you selected a mode that did not require the balance lead to be connected.
