- Granite
- Kraton 6s
- Vorteks
Hello, I searched, but couldn't find the answer.
- Can I use a standard pinion (ex.: https://www.arrma-rc.com/part/AR310424 ) with a new 3S V3 having the Safe-D system, or do I have to use the Safe-D version ( https://www.arrma-rc.com/part/ARA310998 )? I presume the motor shaft is the same and either can work. Am I right? Thanks!
- If I change the plastic spur on an Arrma 3S for a metal one ( https://www.arrma-rc.com/part/ARA310945 ), I think I only need to add a slipper pad in the slipper assembly, right? Can I use the stock 0.8mod pinion directly, or should I upgrade the pinion to a harder material also?
Thanks a lot!
Thanks a lot!
