The 4s shafts are exactly the same as the 3s but just longer and you can't run then without also running 4s arms, 4s hubs, and 4s hexes which also means switching to 17mm hex sized wheels or swapping your 3s axle shafts to the 4s axles but I am not sure if that will work with the 4s hubs.The 4s outcasts has plastic drive shafts so it can work but it’s all about having the slipper set right.
Good to know. So I can swap arms and driveshafts onto the Big Rock from the Kraton 4s?Just pull up the exploded view of the 4s Kraton. Everything will interchange. I agree what was said earlier though, the slipper on 4s seems to be a poor design choice. This thing on 3s is already beast mode!
Yes everything will interchange as they are the same skateboard chassis underneath. The brace is the major addition (outside of drive train) that is different between 3s and 4sGood to know. So I can swap arms and driveshafts onto the Big Rock from the Kraton 4s?
