Granite 3s too big....ugh
Gramyiv801
So I have upgraded my granite voltage to brush list that thing is a beast but I want to do 3S so I ordered 2 3S and I got them and they are too big for the battery tray can anybody let me know what 3S I could run that will fit my battery tray below r pics of the 3s I bought that r 2 big. Please let me know what 3s will fit in the battery compartment. Thank u
Gramyiv801
The 2s I'm running r 5200mah. If I kept the same will it be the same power n speed or will increase?
It gimme:
Snowmandk
What are we supposed to tell you, that you can´t figure out yourself?
You have the dimensions of the battery tray, just buy a battery that´s equal or smaller in size and it will fit...
Running a lower mAh battery will, in most cases, reduce your runtime, but not the top speed or power (yes I know, unless the lipos discharge rate is too low to handle the amps your setup is pulling...but lets not go there just yet)
Running a 3s instead of a 2s is going to give you a theoretical 50% increase in speed and power (to some extend), because you are increasing the voltage by 50%.
Velodromed
There's many a slip 'twixt the cup and the lip.
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Notorious
  5. Typhon 3s
  6. Vorteks
  7. Voltage
  8. Infraction 4x4
I had three granite Volteges and spent a lot of time upgrading them over the course of year before going back to brushed to set ups. Bottom line is if you want a brushless, fast car you need to get a 3s Granite, big rock or similar. I documented everything in the below thread about my voltage difficulties.
Thread 'Voltage 2WD brushless conversion, Velo’s learning curve build.'
https://www.arrmaforum.com/threads/...conversion-velo’s-learning-curve-build.39035/
GraniteFox
ArrmaForum Fan
Delaware
  1. BigRock
  2. Infraction
  3. Outcast 6s
  4. Typhon 3s
Probably time to retire the voltage. Gearing and drivetrain will probably only last a couple packs before it self destructs running on 3s. If you already invested money in a 3s system look for a used roller 3s on eBay or other. Probably can pick one up pretty cheap without the electronics.
SrC
RC is a lifestyle choice
Hospitality Award
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
  7. Typhon 6s
+1
I don't own one, but this is from the Granite manual. Good luck. (y) 😁 ✌️
Have to agree.
The 2s lipo dimension specs are straight forward. Stay with a 2s pack. Or just stay with the OE 18650 cells. (LIons)
Return that 3s. Or just buy a 3s rig that will fit that 3s Zeee lipo.:giggle: And leave the Voltage "as is". A backup rig and for the kids. Don't invest any more $$ into it. It will never become what you want it to be, all the while falling apart very easily. Electrics included.
My spin.
Gedrick
New Jersey
  1. Kraton 4s
I agree with what everyone's saying, return the batteries or get a new car that can properly run 3S LiPos.
That being said, every car has a listed spec of the maximum battery dimensions (for obvious reason), typically right on the product page. In the case of anything Arrma, every single product page has them right on the bottom, search the page for "battery tray" and you'll find it. This is from the Granite Voltage product page.
It sounds obvious but before I got my first "big" battery (the Zeees are huge, and I got a 6000mAh 3S - it is massive!!) I figured my Rustler 4x4 battery tray was "huge" and therefore would fit anything - and then I realized I need to read battery sizes better :LOL:
Definitely need to do homework before dropping coin on a battery in the future (y)
Funcentric
A 3S BLX Big Rock can't handle itself as it is stock. Running 3S in a Voltage is going to be far from reliable. Maybe a fun project if you have parts on hand and just experimenting, but I wouldn't expect too much out of it.
